Brief Description: Aileron Rigging 1: Set bell crank neutral
Next per plan is to connect up the ailerons and adjust the push rods so they are neutral with the stick location.
First you set the aileron's to neutral per drawing, and adjust the push the rod until the bell crank is in its neutral position per the tool. But, recall back I had already set the push rod from the bell crank to the aileron in its proper length for neutral. I did this to make sure I got the flaps and ailerons matching.
But I did double check and everything is neutral. So I clamped the flaps and ailerons together to set the sticks.
