RV-7A Construction Log
RV-7A
Fuselage After Flip
12-16-2009
Flap Push Rod Hole 1: Initial cut
Next is to assembly the flap push rod and make the hole in the fuselage for it to go thru.
I put the flaps back on. I used the cut off wheel to make an intial cut in between the holes I had drilled earlier in this location.
Put flaps back on
This is what I start with
Initial cut
RV-7A Home
1764
53
Cert & Flying
62
75
Cowl
48
181
148
238
Fuselage After Flip
385
237
Gear
78
57
Shop
Training Projects
437
