Now that the wings are in I can remove the outboard saw horses and level the fuselage.
I put blocks in the outboard saw horse to raise the wing tip during insertion and alignment. And after the pins are in I moved them out of the way. I moved the inboard horses out of the way to. So that the fuselage is resting only one its saw horse.
The only thing I had to do for leveling was raise one side a little with a piece of wood under the fuselage. Longitudinally I had already leveled and it was still level.
