It is time to put the landing gear attach weld mounts into the fuselage. I spent a lot of time on these earlier getting them to fit so we'll see how it goes.
First I have to remove all these bolts and spacers that have been holding the wing spars apart. And I took off two of the brackets that will later hold a cover and fuel lines.
Then I tried the right weldmount and it went right in. No apparent issues at first glance.
