Brief Description: Flap Mechanism 12 Install Side Covers and Drill
To finish the installation prep, I installed the side covers and match drilled the holes to the rear brace. With the covers installed, this firms up the position of the aft brace so I match drilled it to the top of the 705 bulkhead.
I also installed the motor. Per plans you run the motor until the shaft is out 50% which is about 3 inches. Then you install it with bolts both at the motor and to the weldmount arm. This helps position the front brace and for final drilling of the little angle holding the motor (no photo).
But now I'll remove, debur, add platenuts, prime and paint.
