Brief Description: Flap Mechanism 7 Spacer and Attach Bracket
Following the plan, I made the spacer. I smooth the ends by inserting this in the drill press and pressing the end on sand paper while turning it. Really makes the ends of the spacer smooth and straight.
There is an attach plate that gets cut to size and bent up 28 degrees. I used my Harbor Freight bender to bend it up.
