RV-7A Construction Log
RV-7A
Fuselage After Flip
12-1-2009
Flap Mechanism 4 Trim Center Cargo Floor Cover
I measured the straightness of the flaps weldmount by mounting it in the bearing blocks and measure it while turning. It is exactly straight.
I mounted the weldmount into the fuselage. I located the mid bearing block. And trimmed the cargo center floor cover to clear it.
Measuring straightness
Mounted in fuselage
Trim off center cargo floor cover
RV-7A Home
1764
53
Cert & Flying
62
75
Cowl
48
181
148
238
Fuselage After Flip
385
237
Gear
78
57
Shop
Training Projects
437
