Next I worked on the plate that holds the fuel selector. The Andair valve requires a 1 inch hole drilled in the center of this plate. I drilled it with a hole saw.
Then three holes are drilled for #8 screws. I used a level to help ensure I got the clocking correct. I used the pump itself as a guide for drilling the holes. I could have used the top but it is decorative and I didn't want to take a chance on scratching it.
