Brief Description: Rotisserie 3 Bushing for bolting on brackets
I removed the engine mount and enlarged all the holes to 1/4 with a step drill. I made them 1/4 because 1/4 bolts are better it seemed for attaching the rotisserie.
I used the engine stand from Harbor Freight. I picked up a few 40 cent plastic bushing s to slide into the attach arms that came with the engine stand to help keep bolts centered.
I picked up some hardware store 1 inch aluminum angle. Measured drilled, cut and bolted until this rotisserie was done. It took all day. I had several attempts that didn't work well.
Biggest problem was the attach arms wouldn't clear the vertical part of the stand when I did a 360. I finally discovered that the vertical stand was tilted backward. This caused a lot of problems.
