RV-7A Construction Log
RV-7A
Fuselage After Flip
11-5-2009
Seat Backs 6
Next I drilled the 4 weight lightening holes. Each is 2 1/4 in diameter. I used the fly cutter on slow speed on the drill press. Works good. I weighted the removed disc. Total weight savings is 1.8 ounces. shshsh, why bother.
Measured and marked for holes
Fly cutter removing the 2 1/4 disks
Total weight savings 1.8 ounces
RV-7A Home
1764
53
Cert & Flying
62
75
Cowl
48
181
148
238
Fuselage After Flip
385
237
Gear
78
57
Shop
Training Projects
437
