Brief Description: Install Step 5: Rivet and Bolt it on
Last step I put the steps in place and bolted on the plastic block first.
Then with help from Bob we riveted on the step. I used the Universal rivets as called out. I had wanted to use flush rivets, but I don't think I could have done a good job of accessing all the flush mfg heads because space is tight.
I was able to easily reach all the rivets with the Tungston bar. The one shop head that was adjacent to the skin rivet set just fine right next to it.
