Brief Description: F-656 Corner Brackets Drill & Rivet in place
While the skins were on I drilled one hole in the corner brackets and then finished drilling and preparing the corner brackets.
The forward pair on the F-706 bulkhead use flush rivets. I had a hard time dimpling the outboard most hole. I ended up using a clamp with my dimple dies.
The other dimples and rivets were all squeezable with various yokes.
