Brief Description: F-656 corner brackets position and prep
Next is the F-656 corner brackets. They look straight forward, but turns out they don't locate unless you put the aft skins on. So I will install the aft top skins and all the stiffeners before drilling these little brackets.
I drew a line on the aft bulkhead flange so I could double check hole position.
The top skins were hard to put on. Hard to get holes aligned and it feels like you have to stretch them down over the bulkheads. Starting at the apex and working down seemed to work the best. I put clecoes in every hole.
