Brief Description: Canopy Decks: Static Line Clips
I noticed on the drawing it shows these clips for holding the static line under the longeron. So I made about twenty of them from .025 sheet. I folded them with my fingers around a 1/4 inch drill. I finished squeezing them shut in a vice. I also drilled them with a #40 and ensured the holes lined up with each other.
Then I drilled out 4 rivets I had put on the longerons inbetween the seat back bulkhead and the wing bulkhead and rivet on four of these clips. They are about 6 inches apart. And I also put a coup forward of the wing bulkhead under the forward canopy deck.
I did these now under the canopy deck so if I rivet on the canopy deck these clips are done.
