Brief Description: Pick Ups: Wing rear spar bolt and Cherry Max rivet
After flipping over the fuselage I started remembering and seeing some little things to finish before moving on to the aft deck.
I had taken out the bolt in the rear wing spar to clear for riveting and I put it back in. And this time I put it in per convention from forward towards aft.
I had one bad rib hole that got enlarged so I used a fat cherry max rivet to finish it off.
