These high pressure hoses from Van's seem way to long. The are rubbing against the firewall. I'll have to go investigate what others have done. I could order new shorter ones but that's money. Maybe I can attach them together and to the pedals somehow so the don't rub on the firewall. I could put plastic tubing overthem, but might they get too warm for that?
The high pressure lines have to be off set to clear the connection for the low pressure line. I off set them toward the pedal rather than toward each other to avoid any chance that they would bump into each other when pushing the pedals.
