I installed the stick assembly. I put in the bolts, torqued them and put on the latex paint. So I hope they are in for good.
Then I hooked up the springs from the aileron trim to the sticks. This uses a piece of stainless safety wire. I balanced the spring tensions and the stick is straight up for now. I'll probably redo this wire again later.
