The tube that goes up the middle from the pump needs to go down and outside then forward to the firewall fitting. So I put a 90 degree AN fitting on the pump then attached the fuel line. Length is okay. It might be an inch to long.
My lengths are:
Tank lines are 38 inches with a 90 degree fitting at one end Center line is 20 inches with straight both ends.
The short tube that goes from pump to selector will have to be made from aluminum tube because the run is too short for Bonaco fittings.
