Before I can finish the fuselage skins I need to mount a bracket for the eventual ADAHRS from Dynon. I got the drawing off their web site. I reviewed other builders brackets on Vans Forum and decided on this bracket.
First I made it out of paper. Then cut it out of .032 aluminum. I bent up the sides. I left a front on it which I will eventually drill for plastic busihngs for the pitot static lines to run thru so to relieve stress on the interface of the tubes with the Dynon ADAHRS.
