RV-7A Construction Log
Date: 4-11-2010
Number of Hours: 0.10
Brief Description: Fuselage Final Items: List of future pick ups
I've this list of things on my mind to do to finish the fuselage, but I think I'll wait and do them when I obviously have to. Rule of thumb at this point is, "don't rivet stuff on until you have to" so you have access to do things like wiring, building plateforms for ADAHRS things, putting in other parts, etc.
1) Install aft top skins 2) Install aft wiring for light, trim servo, ADAHRS, elevator servo 3) Build platform for ADAHRS 4) Install new fuel lines, pump, firewall penetration (steel braided teflon) (I've decided there is no place for aluminum tubing for fuel in the cockpit nor engine compartment). 5) Finish installing all tubing 6) Install rudder / brake pedals and all the parts 7) Install Sticks and push rods 8) Install flaps mechanism 9) Install roll bar and the top frame parts (probably needed for making canopy 10) Rivet on forward frame (skin won't go on until panel is done.)
That's about it to finish the fuselage. So I'll be back.
