RV-7A Construction Log
RV-7A
Fuselage After Flip
4-8-2010
Fuselage Final Items: Fwd Elevator Push Rod 2
I cleaned and primed the fwd push rod.
I played around with how to install this and discovered you bring it in along side of the cargo bulkhead and with the bearings off.
I installed the sticks with a couple bolts and clamps.
Then I hooked up the pushrod and it worked fine with no interferences.
Primed the push rod
Installed the sticks
Installed the push rod from side
RV-7A Home
1764
53
Cert & Flying
62
75
Cowl
48
181
148
238
Fuselage After Flip
385
237
Gear
78
57
Shop
Training Projects
437
