RV-7A Construction Log
RV-7A
Fuselage After Flip
4-4-2010
Fuselage Final Items: Electric Aileron Trim 4
I dimpled the bracket on the big dimpler. And dimpled the floor ribs using the squeezer. These are #8 dimples.
The block gets drilled to the bracket using the block's holes as a guide.
Then I drilled and installed platenuts per drawing. I dimpled the #40 platenut rivet holes and platenut wings for a flush side.
Dimple ribs #8
Match drilling block to the bracket
Platenuts installed
RV-7A Home
1764
53
Cert & Flying
62
75
Cowl
48
181
148
238
Fuselage After Flip
385
237
Gear
78
57
Shop
Training Projects
437
