Brief Description: Fuselage Final Items: Electric Aileron Trim 1
Next pickup on the fuselage is to install the electric aileron trim. I didn't do this when the wings and stick were installed. The impact is more on the floor ribs then on the stick and aileron. The kit comes complete with all the parts.
First is to chamfer the block to fit the curvature of the bracket. Then make a notch to access a cotter pin. And then drill some mounting holes.
The mounting holes have to be perfectly straight so I used the drill press to drill them with #10 bit.
