Brief Description: Fuselage Final Items: Air inlet scoops 5
I mixed up some proseal. The proseal has a short life span per the date on the can. But old-timers have told me if it is still soft enough to mix up and use then it is still good enough to use. Basically when it goes bad, it is too bad to work with.
