Brief Description: Front Deck (Tip Up) 31: Rivet on side brackets
I took apart all the forward fuselage structure. It will go back in when I get to the canopy. But before then I have some things to finish.
The side bracket for the air vents get riveted on. I started to squeeze the rivets but bucking them was easier and better. I had previously dimpled the holes.
