Brief Description: Front Deck (Tip Up) 20: Drill top skin
The skin is really hard to stretch across the top ribs. I probably should have removed the celephane. The one corner hole is really looking iffy at this point. I hope it closes up better later.
I did not redrill the holes along the longeron. Those are already dimpled. So I did just drill the skin holes to proper size.
Next is to drill the center rib to the firewall. So I opened up the side of the skin, removed one rib and was able to reach this with the angle drill.
