Brief Description: Front Deck (Tip Up) 16: Platenuts & Rivet
Plans call for the platenuts to be installed in the aft ends of the ribs now, so I did. I see why. I'm going to assemble this forward fuselage area including the panel and drill some extra brackets.
So I also riveted together the parts previously drilled and primed for the mid-sub-panel. Now that I've done this, I think I would have just clecoed this together for the next step and then riveted itall later. But it was easy enough with it riveted.
