Brief Description: Front Deck (Tip Up) 13: Engine Control Bracket
The engine control bracket will eventually hold cables for throttle and mixture. This goes on the interior sub panel. There will be another that goes on the pilot panel.
I studied the drawing and discovered that you locate this by first drilling holes in the bracket per drawing. Then locating it one inch overlap on the sub panel. And I decided to have it centered.
This gets 4 holes so I used my accordian drilling tool again just to find two evenly spaced holes. I like this tool.
Then I clamped it in place and drilled it. One inch overlap and centered.
