Brief Description: Front Deck (Tip Up) 12: Fwd Fuse Channels
Next I made the two fwd fuselage channels and drilled them in place. I cut this on the band saw and sanded them to final dimensions on the belt sander. Then I located them on the sub panel and drilled them with the long 1/8 drill bit.
These channels fit flush with top flange because the skin will get riveted to them.
