Brief Description: Front Deck (Tip Up) 11: Trim and fix 2 close holes
There is a spot that needs trimming on the flange of the center sub channel.
There is also a hole that holds the angle that interfers with the center sub channel. I've decided to use a NAS rivet here so it fits under the angle of the fwd fuselage channel. I gave this a slight countersink to accept the small flush head of the NAS rivet.
