Brief Description: Cabin Frame Roll Bar 40: Paint channel parts
I also decided to fill the pulled rivet holes. So I put a little spot of rage in each hole. I cycled thru sanding and refilling about 3 times. I used 180 course sand paper. It went pretty fast. This is the first work with any filler or fiber glass. The garage stinks.
After thorough sanding, cleaning, and degreasing ai Primed the roll bar.
