Brief Description: Front Deck (Tip Up) 8: Make Angles
This angle has to be 1/8 inch down from the top so that the round weather stripping will fit in here later. So I clamped my yard stick to the edge and used a 1/8 aluminum spacer to draw a line on the part. I clamped the angle to the line and drilled it.
