RV-7A Construction Log
RV-7A
Fuselage After Flip
2-26-2010
Front Deck (Tip Up) 6: Make Angles
Again I marked the cut off lines at 15 degrees with my protractor. Then I used the tin snips to cut out these pieces. And not shown is a bunch of sanding to make all the edges smooth.
Marked cut off lines and snipped
Two more angles done
RV-7A Home
1764
53
Cert & Flying
62
75
Cowl
48
181
148
238
Fuselage After Flip
385
237
Gear
78
57
Shop
Training Projects
437
