RV-7A Construction Log
RV-7A
Fuselage After Flip
2-22-2010
Cabin Frame Roll Bar 34: Riveted Angles
Before pop riveting the two halves of the frame together, I took them apart and riveted on these to angles that hold the overhead channel.
Also, I was able to debur and clean out the inside of the channel. I recommend don't rivet these together per plan, but wait till now to do it.
Rivet on these 2 angle brackets
Used channel and riveted angles
RV-7A Home
1764
53
Cert & Flying
62
75
Cowl
48
181
148
238
Fuselage After Flip
385
237
Gear
78
57
Shop
Training Projects
437
