Brief Description: Cabin Frame Roll Bar 33: Prime scratches
The roll bar frame is now all drilled and ready to come off. I still have to rivet it together the rest of the way with pulled rivets, but only after I mount the bracket angles at the top.
I used a little alcohol to wipe down where I had trimmed away material and drilled new holes. Then I shot the area with primer. The alcohol doesn't mess up the primer, and it does clean grease/oil off the aluminum for priming.
