Brief Description: Cabin Frame Roll Bar 32: Drill inboard holes
Last holes to drill are the inboard two holes. The drawing said to drill the holes in the angle with the frame, so I did not drill any holes in it to use as a guide. Even if I had it would be difficult getting the angle drill in there to drill outward.
So I just measured hole location per the drawing and drilled them from the outside. Worked fine. These are AN3 bolts.
