Brief Description: Cabin Frame Roll Bar 26: Sand off angle edge
I used the belt sander to sand down the outside edge of the angles to match flush with the fuselage side skin. I had to buy a new sanding belt.
Before finishing the drilling of the frame and angles, the plans turn to an overhead channel and spacer. This is a revision that Van's came out with later in the 7A design. These holes get drilled to 1/8 instead of just #40. So I positioned these parts and drilled them. I'll debur and dimple after I dis-assemble the frame.
