Brief Description: Cabin Frame Roll Bar 25: Drill the angles
I drilled the 1/4 holes. But I did it using small bits and working up. When done it looked good except it is slightly inboard from flush with the bottom skin. The aft edge hangs over as it should and I'll grind that off.
