Brief Description: Cabin Frame Roll Bar 16: Rear Angle Squeeze
The long angle needs to be closed 2 degrees. So I put it in the vice and pinched it slightly. Sure enough when I measured it it showed 88 degrees instead of 90. Amazing.
I positioned this angle on the aft channels and match drilled it using the holes already in the plate and channels.
