Brief Description: Cabin Frame Roll Bar 3: Clamp it
Then in preparation of clamping it down, I cut some blocks 1 3/8 wide. Because later you clamp the halves together and need a 1.5 inch outside distance. Each is 1/16 thick.
I measured the width I wanted and clamped angles in the position to hold the lateral dimension.
