Brief Description: Cabin Frame Roll Bar 2: Drill the hole
Next plans say drill a 1 1/2 inch hole. Turns out the center of the hole is just off from the tooling hole. So I used the drill press and clamped this in an attempt to hold drill right over the spot. But I think the bit bent a little and hole is slightly off, but un-noticable.
