RV-7A Construction Log
Date:  6-7-2017
Number of Hours:  1.00
Brief Description:  Baffle 24 Snorkle
I finished the gate install and moved to finishing the cable install for this gate. I had to locate and drill a hole thru the firewall. I chose the location on the pilot side right in line with the gate.
I added a firewall passthru. I had this one left over in inventory. It is a bit complicated but worked well.
I added a couple of adel clamps per plans.
I cut the cable to length and twisted the end around the part of the gate that opens, all per the drawings.
Firewall PassThru Gate Cable
Gate Cable Routing
Gate Cable Routing
Cable termination at Gate
