Brief Description: Mount the Engine 5 Throttle Linkage
The arm on the throttle was clocked wrong similar to the Prop Govenor and Mixture. So I loosened the bolt and put it where it needed to be. There are little teeth that hold it in place. There is also a cotter pin on the throttle bolt.
