Next I decided to finish off all the bolts that hold the ribs to the 704 bulkhead. I examined the drawing and noticed that the bolts insert from the rear going forward. So I put all mine in this direction and torqued them to 25 in-lbs
Then I found my column control mounts and bolted them on to. I had thought I'd drop these in later. But looking at access for the nuts I'd rather torque them now and then drop in the steering column and bolt it to these mounts.
