Well per the plan I'm at the point to dissassembly the fuselage, debur, dimple, prime and rivet back together. But some things haven't been done yet. There are several places that have not been drilled yet. Did I miss these? I'll have to go read back thru some construction logs and see why these are not done yet and make sure I didn't miss something important.
1) The outboard seat rib has not been drilled to the skin. 2) The outboard baggage rib has not been drilled to the skin. 3) The aft end of the mid-fuselage has not been drilled to the fwd end of the aft fuselage
