I mounted the rudder assembly into the fuselage. I added the center bracket and match drilled the holes thru the firewall stiffener. Then I match drilled the holes thru the plastic block. I moved the whole assembly to the second and third position and match drilled thru the center block into the center bracket so now all three positions are fully ready..
