Brief Description: Fwd Fuselage - Lower Longeron F 717 1
The Lower Longeron was easier to do then the stiffener. I found the raw material and cut the two longerons to length. Then I measured and drilled a relief hole and cut off one side of the angle per drawing. I had to do some filing and sanding to get the vertical side of the angle smooth and with no bump from the side that got cut off.
But when I put it in place I noticed a gap between the longeron and the weld mount on the firewall.
