I started off wrong on the F-719 forward side skin stiffener. I made the angle clip per drawing, but soon realized I should NOT have made the single hole in the vertical leg. Because there is no way to match drill with it. So I made two more clips.
Next you need to make the width necessary for a smooth flush fit between the side skin and the firewall stiffener. The dimension on drawing was slightly larger than I needed.
