Brief Description: Fwd Fuselage - Straps Bulkhead to Longerons
Next you make these little straps to hold the longerons on to the wing bulkhead. Good thing because they are only balancing on there now with a little support from the skin. These are made of .062 aluminum. I found these four pre-cut pieces so I'll bet these are the ones I'm suppose to use. I cut them a little longer than the drawing because it looked like edge margin would be to close.
