Brief Description: Mid-Aft Body Join - Flute and Drill Arm Rests
Finally my brother Ed called and pointed out that I had not drilled the arm rests. So I restudied the drawing and found the ommission. So today I flutted and drilled the arm rests. I took them off and stored for later use.
I did this work after drilling the firewall but inserted in my construction log here, because here is where you are probably looking for it.
They seem kind of flimsy. Later I'll hunt around for ideas on how to make these sturdy.
